radio shuts off and on
  • franco90
    • 3185
    I need your guys help I have a small problem.
    Once I start driving my car the aftermarket radio shuts off and on
    lately its doing it alot. so please help me out before my radio burns up. thanks Franco
    I've always been proud of being a Marine.
    I won't hesitate to defend the Corps
    "Supersquad"
    ‎"Prostitutes are a sub-category of Amusement Parks"-
  • DaveSmed
    • Apr 2007
    • 1407
    That sucks. Odds are its an inadequate connection behind the radio.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • franco90
      • 3185
      I will check the connections thanks
      "Supersquad"
      • Schnitzer318is
        • Jan 2008
        • 2057
        Do you have amps and a full system? Do you have a voltmeter to check? Your car's charging system might be dropping below 11-12v... that would cause audio equipment to reset. Could be alternator or battery? Or could just be a loose connection as stated above.
        GL
        "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
        91 318is Turbo Sold
        87 325 Daily driver Sold
        06 4.8is X5
        06 Mtec X3
        05 4.4i X5 Sold
        92 325ic Sold & Re-purchased
        90 325i Sold
        97 328is Sold
        01 323ci Sold
        92 325i Sold
        83 528e Totaled
        98 328i Sold
        93 325i Sold
        • franco90
          • 3185
          I do have a system but i got a new battery and a new alternator But i will also check that thanks again
          "Supersquad"
          • scm320
            • Aug 2007
            • 57
            SAME THING HAPPEND TO ME! okay so first check your grounds. then check your remotes. makes sure they are all well connected.
            Now i have a question for you. how watts is your sub and how many watts is your amp. Chances are that your amp is shutting off because its overloading and its connected to your deck. so you need a more powerful amp for your sub. thats what happen to me and my friend and we both have e30's check it out man. good luck
            Having a fast honda is like coming out of the closet.....you suprise everyone at first, but in the end you're still gay
            • Addissimo
              • Mar 2004
              • 1820
              Doing something M50 related? -> http://www.addissimo.com
              On Myspace? ->http://groups.myspace.com/r3vlimited
              BF2142 SN = BillyGoose
              • TwistyTunedE30
                • Jan 2005
                • 499
                heh...i couldnt figure out why when i turned the e30 on why my amp only came on with the radio...my special remote/switched source happened to be the power to the damn antennae. Radio electrical is easy fix and generally isn't a detrimental effect on the deck or system.Yay for fuseable links
                • franco90
                  • 3185
                  I think my battery is fuck up i have a new alternator now my lighta r dimming when I am at the light.
                  "Supersquad"
                  • DaveSmed
                    • Apr 2007
                    • 1407
                    Could we get an english translation?
                    -Dave
                    • StereoInstaller1
                      GAS
                      • 22679
                      Didn't you mean to say "Ohms"? If not, that may possibly be the dumbest thing I have heard in regards to audio on R3V.
                      Closing SOON!
                      Thanks for 10 years of fun!
                      • franco90
                        • 3185
                        when I am at the stop light my radio shut off and on.
                        my lights dim alot like the car is going to shut off .I give it gas and my lights and radio work fine.
                        "Supersquad"
                        • StereoInstaller1
                          GAS
                          • 22679
                          Franco, it sounds like your car is not charging.
                          New does not mean "good", new means good.
                          Go have your charging system analyzed. Should not cost much if anything, lots of places here do it for free. Make sure your battery works properly. Heaters and windshield wipers and rear defrosters use up a lot of power, so your alternator/battery just might be weak.
                          Go get it checked out.
                          Luke
                          Closing SOON!
                          • franco90
                            • 3185
                            Stereo
                            I will do that thanks
                            "Supersquad"
