Install under way.. help/opinions welcome.
  • ibavarian
    • 94
    Lets start by saying that i'm a noob as far as aftermarket systems. Im pretty good with electronics though so i'm hoping this will go smoothe. Here's what I have so far. Also.. im not looking for off the chart bass. I just want an upgraded clean note with a touch of bass.
    Equipment came from a S13 I had. I ripped it out in 30min cause seller wanted 200 bucks off the price :grin: Anyways..
    Panasonic DF903U- Temporary.. want to upgrade to pan. 7413 in near future.
    Sony 5.25 in front- Cant remember the model..open to suggestions for upgrade
    Alpine MRP F240 AMP (4/3/2 channel)
    2 SET of tsunami RCA's (4 leads total)
    Im undecided if I just want to run the AMP to 4 speakers or 2 channels to the front and bridge a third channel to a sub. Reasons- I have a 4door and no ski hole. I fear having a 10/12 sub in the rear wont do much and cause rattling if pushed wich I DONT want. But i'm also leary of running the amp to just speakers as I may not get the bass im looking for. So i'm open to suggestions from those who have done both.. Luke? I'll most likely run fresh wiring..
    Thanks!
    "Full throttle till you see god, then brake hard"
    90' 325i f0 door
    06 Kawi ZX6R
  • falcon64
    • Nov 2007
    • 73
    does ur cd player havesub controles
    • smonkbmw
      Professor
      • Jun 2006
      • 4549
      i thought all cars had ski holes? pull out the rear seat and punch the center out? id run the amp in a 3 channel set up and pick up one of lukes boxes.
      • ibavarian
        • 94
        yup
        90' 325i f0 door
        06 Kawi ZX6R
        • StereoInstaller1
          GAS
          • 22679
          I have yet to find an E30 without the ski hole. Pull the trunk liner and check. Shouldn't take more than 5 minutes...
          Luke
          Closing SOON!
          Thanks for 10 years of fun!
          • ibavarian
            • 94
            Oh i see..I didn't know I get to use my hammer on this project.:D
            Should this amp be enough to power a sub. It's a 350W peak output amp. RMS 40 x 4
            That being said.. I have a CC giftcard for 100bucks, any recomendations?
            90' 325i f0 door
            06 Kawi ZX6R
            • StereoInstaller1
              GAS
              • 22679
              Oh yeah, hammer time!
              what amp is it?
              sell it on Craigslist for $75 and buy good used stuff?
              Closing SOON!
              • ibavarian
                • 94
                I'm starting to lean more towards just running 4 speakers off this amp and possibly change the set up and add a seperate amp/sub down the line. Any recomendations on speakers? thanks..!
                90' 325i f0 door
                06 Kawi ZX6R
                • StereoInstaller1
                  GAS
                  • 22679
                  that little F240 is a decent amp, but gutless. Basically, use that as power for a decent set of fronts and add a subwoofer with about 300 watts RMS.
                  Closing SOON!
                  • einstein57
                    • Jun 2007
                    • 10780
                    The best buy by my house has a 1000 watt kenwood on clearance for $80. I think i'll buy it as a spare or for a later install since its so cheap. Check your local best buy for killer open box buys. The only thing that rattles with my one twelve when i realy turn up the bass is the rear shelf. I figure some insulation foam should do the trick.
                    www.gecoils.com
