stock amp.
  • viali8
    • Nov 2005
    • 673
    stock amp.
    My brother just bought a 89 325is and his stock sound system blows my stock sound system away (89 325i). I know that he has the premium sound speakers, tweeters, etc. My question is does my 89 325i have the same stock amp as his 89 325is? I see the stock amps for sale and am tempted to buy one. what do you think?
  • StereoInstaller1
    GAS
    • 22679
    Stock amps suck balls. Any modern deck makes far better power, and likely more, too.
    If you are gonna use the stock deck, the factory amp is an option, but if you are going to use an aftermarket deck, just bypass that stock amp alltogether.
    Add some premium sound tweeters, though...big help in the highs.
    Closing SOON!
    Thanks for 10 years of fun!
    • viali8
      • Nov 2005
      • 673
      stereo
      As you can tell i am not educated in car electronics. I want to keep the look stock, i just added some tweeters and am in the process of getting the premium speakers for the rear deck. I want to remove the old speakers/tweeters but keep the stock look. What can you recommend as an inexpensive upgrade for the...
      1.) speakers
      2.) Tweeters
      Keep in mind i want to replace my head unit with a stock 89iS unit.
      thanks matt
      • StereoInstaller1
        GAS
        • 22679
        Matt, you can use just about any aftermarket 4 channel amp with the stock 89+ deck.
        If I were looking for that look and were willing to spend the money, I would do a CD43 deck and a decent aftermarket amp on stock premium sound speakers.
        Closing SOON!
        • -limp-
          • Aug 2007
          • 138
          dont mean to thread jack but do you know how to take the grills off the tweeters i got em off a junker and they are dirrrrrrty
          • StereoInstaller1
            GAS
            • 22679
            The grille is part of the panel, removable by Dremel only.
            You can pry the tweeter out carefully from the backside.
            Closing SOON!
            • elguapo84
              • Oct 2006
              • 965
              Luke - Is there a way to integrate the factory amp with my Panasonic C7413U or do you think it would sound much better than just using the power from the deck? The guys @ bestbuy think we can split up RCA cables and run them to the preamp on the deck to integrate...basically I don't want to spend a bunch of money on an aftermarket amp right now, and I thought a little added power might be nice...
              An unlucky E30 I came across in Rotterdam, Holland
              • StereoInstaller1
                GAS
                • 22679
                The Panasonic makes more power than your stock amp, and better quality too.
                However, the BMW amp does make a decent paperweight.
                Closing SOON!
                • elguapo84
                  • Oct 2006
                  • 965
                  OK, so remove and bypass the factory amp...seems pretty straightforward.
                  Now I need to figure out a good way to mount my sub in the trunk. I want to keep the ski pass-through intact, so I can't mount it right behind the seats. I was thinking of hanging it from the top of the trunk with adequate space for the trunk hinges to still move, and facing the speaker downward. It's one of the compact 10" low profile subs, so it's not very deep. What do you think Luke? Any ideas?
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    You need a box for it to sound good, basically. Why don't you want to punch out the ski hole?
                    I'm not absolutely sure, but I think if you port the box into the cabin, you can get away with leaving the ski hole intact.
                    • James Crivellone
                      Head Janitor
                      • 6303
                      Stop dissin my bathroom radio f00!
                      • StereoInstaller1
                        GAS
                        • 22679
                        Have you yet made a TP holder out of a shifter?
                        Closing SOON!
                        • James Crivellone
                          Head Janitor
                          • 6303
                          Hah, not yet
                          • viali8
                            • Nov 2005
                            • 673
                            Thanks for the help. What is the CD43 deck?
                            • StereoInstaller1
                              GAS
                              • 22679
                              That would be the single disk deck from an E36, AKA "Business Class" deck.
                              Closing SOON!
