removing the tweeters from the sail panels
  • der affe
    Technical
    • Dec 2005
    • 8452
    what is the best way to remove the stock tweeters (other than carefully) from their panels in the doors with out breaking them?
    i am upgrading all the speakers and want to upgrade the tweeters and reuse the stock housings.
  • AndrewBird
    The Mad Scientist
    • 11898
    They are just hot glued in. Carefully cut around them (from the back side) and pry them out. The grills can't be removed without cutting them off.
    • der affe
      Technical
      • Dec 2005
      • 8452
      cool! i wasn't sure if they were epoxied in or what it was holding them in. i have some lanzar components i am putting in their place. (they were free from a part out) keeping the grills so they still look stock.
      thanks again.
      • netcsk
        • Apr 2004
        • 1609
        I'd use hot glue to put yours back in, as its a good strong way to do it but also allows you to remove them in the future if needed. Also, remove the cloth piece that goes in front of the tweeter as it very detrimental to performance.
