Base of A pillar door switch wiring?'s
  • Restoman
    • Jun 2006
    • 1311
    Okay, the switch that grounds in the door for the interior lights might be mix matched what color is the wire Brown/Green or Brown/Purple. I am buttoning up every thing in that area and can't find it in the Bentley.
    i'lldoitforacaravan
  • george graves
    • 20003
    Are you asking what wire goes to the switch? I think it's BR/YL or BR/VI.
    Originally posted by Matt-B
    • jht3
      • 288
      br/yl on the drivers side
      br/vi on the pass side
      the drivers side actually has the br/vi wire as well, but it connects to the light timer relay. the relay then connects to the door switch on the br/yl wire. if you want to defeat the timer relay (or yours is broken like mine) you can directly hook up the br/vi wire instead
      James
      '88 M3
      • Disaster Inc
        • Oct 2007
        • 429
        ETM's... http://wedophones.com/BMWManualsLead.htm
        • Restoman
          • Jun 2006
          • 1311
          I'm going to check for the third time.
          i'lldoitforacaravan
          • Restoman
            • Jun 2006
            • 1311
            brown and violet clipped and has no home
            brown and blue connected to door switch
            It's an 87e 2 door
            i'lldoitforacaravan
            • Restoman
              • Jun 2006
              • 1311
              BU/VI apparently have no place in the interior light scheme. What else runs in that area? Just so you know the car has never been turned on by me. I am waiting for alot of stuff to be sorted.
              i'lldoitforacaravan
