Tips on tuning a sound system?
  • Turf1600
    • 9815
    I finally got my sound system from luke installed. It's a monoblock amp, a 4 channel amp, an exile 12'' sub, exile mids and tweeters with exile crossovers. The sound is great but I'm having a hard time getting it universally tuned. It will sound great on one song but then have too little treble on another or some other issue. On the tweeters I have high pass all the way up - mid and bass all the way down. Bass pass is all the way up on the sub. What's a good way to get this thing setup right?
    On a side note, the monoblock amp gets PIPING hot after running it for a while. Is this normal? If not, how may I reduce it?
  • StereoInstaller1
    GAS
    • 22679
    Patrick, I want to see what others have to say on this subject.
    Your bass amp should not be getting very hot, even in Texas.
    Closing SOON!
    Thanks for 10 years of fun!
    • Dozyproductions
      • Jan 2007
      • 4682
      When you are talking about the high pass and low pass are you talking about the cross over settings on your Head unit?
      I had the exile x-tec components and I just liked them how the cross overs had them at. I don't know at what frequencies they are cut off at so I can't further comment on that.
      Pretty much tuning a system consists of, in no certain order:
      1)Location
      2)Playing around with Frequencies
      3) playing with the eq.
      4) TA - (time alignment).
      I would say that if you are set on the location is to just play around with your EQ and certain cross over frequencies. Just as a reminder that the eq doesn't really need to be played around with too much. +1 here and -3 there at most. Just trial and error certain frequencies you need to adjust and see if it gets better or not.
      I had my xtec mids set playing down 60hz at an 18db slope on the unit and I can't remember if there is/I switched the tweeter attenuation on the crossover to low.
      Perhaps my post didn't help at all but good luck!
      • Turf1600
        • 9815
        Lume - I'm going to call you later and we can go over my settings. When I say hot I mean it nearly burns me. What could be wrong?
        • dinanm3atl
          • Feb 2007
          • 7305
          Where are the gains on both amps?
          Where are the amps mounted? Vertical? Upside Down?
          MP3 Disc for a source or store bought CDs?
          Let's start by answering those questions and after that we get the tuning worked out :)
          • Turf1600
            • 9815
            I'll post some pics later. The amps are mounted vertically on the sub box in my trunk. The source is an ipod via usb port on the faceplate. I don't know what gains are. I'm a stereo newb^eleventy billion.
            If it helps, the 4 channel is as cool as a cucumber.
            • Turf1600
              • 9815
              1)Location
              I don't comprehend any of this.
              • dinanm3atl
                • Feb 2007
                • 7305
                Can you take a picture of the settings on the amps?
                Will help out a lot :)
                Also do this for me.
                On the subwoofer amplifier find the "gain" control and put a screw driver in and turn it all the way till it stops counter clockwise or "left".
                Then turn it about 1/4 turn. Then drive around and see if it continues to get scalding hot. Report back.
                • Turf1600
                  • 9815
                  I've discovered that it sounds like shit due to the speaker wire I used on the driver's side. New speaker wire will go in soon. The sub is still hot though - not as bad since I turned the bass boost off - but its hot hot hot.
                  • twistednut
                    • Nov 2007
                    • 272
                    An Ipod is a terrible source to try and tune in a system. Give this a read http://www.cdtaudio.com/amp_gain_set_08.htm
                    what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
                    • dinanm3atl
                      • Feb 2007
                      • 7305
                      Ok I think we have found the problem.
                      Turn off the stupid bass boost and whatever other equalizer crap you have running from the head unit or at the subwoofer amp.
                      Did you check on the gain?
                      • Turf1600
                        • 9815
                        There's no gain knob that I can see. Now, my HU has sub control. I can control the sub from -5 fo 15 - and bass from -8 to 8. Lemme go look and see what knobs I have and I'll brb.
                        • dinanm3atl
                          • Feb 2007
                          • 7305
                          There is not a gain knob on the amplifier?
                          It might not be a "knob". It might be sunken into the amplifier.
                          • Turf1600
                            • 9815
                            Okay - Here's what it looks like -
                            Bass boost: 0db - 18db
                            Level: .3v - 8v
                            Low Pass: 50-25 hz
                            Subsonic Filter: 20-35 hz
                            Then theres a switch from which I choose the following
                            "Config"
                            in - BY Out: BY
                            in: LP Out: LP
                            in: LP Out: BY
                            • Turf1600
                              • 9815
                              http://www.titaniumpower.com/Details...16526417043178
                              That's the amp
                              http://www.titaniumpower.com/Details...27124849127001
                              That's the 4 channel
                              Those are the speakers
