Cluster question
  • BBY1104
    • Jul 2026
    Cluster question
    My Engine Temp gauge bounces from side to side pretty frequently and also my gas gauge now does the same thing.
    What could cause this and for anyone who this has happened to what was the solution.
    I am thinking for temp gauge maybe the nut on the back? or actual sensor?
    and for gas gauge maybe the feul level sensor?
    Pulling cluster tomorrow to see what is up and tighten nuts if loose.
    Also...for later model cars will a 325i(s) cluster work for a 318i(s) if i sawp coding plugs?
  • atomic
    • Jun 2007
    • 5691
    more Matthew Mayhem
    It has been discussed so many times that my head hurts to think of how many threads I have read with these sames issues....
    • BBY1104
      I finally found the answer all late model clusters will swap over with the the coding plug specific to your car.
      My reason for this question was I was wanting to swap in a Euro/canadian Cluster.
      I wanted to know if the coding plugs were different at all. I wasnt sure if the Euro Model cars designated as to what year and what car started using the later model clusters.
      • Jean
        • 18228
        Check the rear nuts on the cluster behind the temp / fuel gauge first.
        Check that the connection on the temp sender unit in the engine bay is good
        If the above does not fix you remove the cluster, check the SI Board and check for bad colder joints on the main cluster board where the rear plugs connect.
        My board had bad/cold solder joints, so re-flowing the solder there fixed it 100%.
        • smonkbmw
          Professor
          • Jun 2006
          • 4549
          this wasnt your original question, you also asked this
          which you asked me via IM and i told you what to do but you waste bandwidth on here asking the same question again. odd.
          • BBY1104
            I didnt hear you say anything bout coding plugs.
            Just curious if Euro ones are different.
            Sorry for wasting everyones time
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              It's O.K. , We have beome accustomed to it. Par for the course.
              • atomic
                • Jun 2007
                • 5691
                X1000000000000000000000000000000
                You would think that someone with that many posts in such a short time, would know how this place works by now....
                Especially knowing the past history of this member.
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  You would think that someone with the number of Usernames in such a short time, would know how this place works by now....
                  Fixed.
                  • smonkbmw
                    Professor
                    • Jun 2006
                    • 4549
                    • atomic
                      • Jun 2007
                      • 5691
                      You would think that someone with that many posts and usernames in such a short time, would know how this place works by now....
                      double fixed :up:
                      • Kwaaahhh
                        • Apr 2008
                        • 843
                        Can anyone help me out on this. So on my cluster, everything works except the fuel gauge. All the lights turn on and the needle works perfectly. I replace the fuel sender unit with a new one and still nothing which leads me to think it could possibly be the fuel gauge unit itself? I read on this forum about the SI board, but can't get a visual of what exactly am I suppose to look for. What can I do to troubleshoot this issue? It bugs me not having the fuel gauge work. Thanks!
