Memphis Pr100.4 for hd-62 components?
  • brn2ply7
    • 301
    Do any of you see a problem with driving my CDT HD-62s with a
    Memphis Pr100.4? If i run it bridged I think it would give me plenty of power...Or what amp would be better for the components in the $100-$200 range?
    HD-65:
    * 6.5" 2-way
    * Midrange: 6.5" Cast
    * Crossover: SatNet-480
    * Tweeter: 1" silk soft dome
    * Power handling: 180 wattsRMS
    * Frequency response: 55-20kHz
    * Sensitivity: 92.6 dB.
    * Impedance: 4 Ohm
    * Surface & flush mount tweeter
    Pr100.4:
    * 400 Watts Output Power
    * 200 Watts RMS Output Power Bridged 4 Ohms
    * PWM Mosfet Power Supply
    * THD (Into 4 Ohm) <0.05%
    * THD (Into 2 Ohm) <0.1%
    * Signal/Noise Ratio: 90dB
    * Channel Separation: 60dB
    * Frequency Response±0.5dB: 20Hz-20 kHz
    * Crossover Frequency LPF: 40Hz-400Hz
    * Crossover Frequency HPF: 40Hz-400Hz
    * Bass Boost: 9dB @ 45Hz
    * Adjustable Low Level Sensitivity Range: 200-4000mV
    * Adjustable High Level Sensitivity Range: 0.5-5V
    * High/Low Level Inputs
    * Low Level Input Impedance: 10k ohms
    * High Level Input Impedance: 100 Ohms
    * Remote Bass Control Input
    * Platinum Finish Terminals
    * Fuse: 25 Amp x 2
    89 325i parts car
    90 325i in progress
    ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
    --tryng to join the schwarz army one day at a time--sigpic
  • brn2ply7
    • 301
    no body
    89 325i parts car
    90 325i in progress
    • StereoInstaller1
      GAS
      • 22679
      Oh shit, I never answered your PM, did I?
      So sorry, sometimes I suck at this kind of shit.
      I am getting a BUNCH of Exile refurb stuff, smoking deals coming shortly.
      I will say that Exile is about the best sounding affordable stuff I have ever heard.
      Soon as I get a cost list, I will PM you.
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • brn2ply7
        • 301
        Thank You!
        89 325i parts car
        90 325i in progress
        • z31maniac
          • 17566
          Luke
          Reary? Does Exile make any one/two channel sub amps?
          Then I could use all 4 channels of my old school Zapco 360 to run the components.
          www.gutenparts.com
          • StereoInstaller1
            GAS
            • 22679
            Standard series "X" amps come in Mono (1 ohm is best) 2 and 4 channel.
            I am using a 600.2 on bass in my car on an XP12 SVC woofer.
            New "Shift" series have 2 small mono-blocks, both intended for a 2 ohm load.
            I did a 500.1 on a single 12, DVC, in a 2002 Celica...silly bass, for sure.
            Luke
            Closing SOON!
