Relays under $15?
  • Sam Cogley
    • Jun 2008
    • 521
    Relays under $15?
    The dealership price for a fog light relay is nuts, but unfortunately it isn't just a regular 5-prong Bosch relay with the 87a terminal missing - two of the other poles are swapped. Anyone know where I can find a functional replacement for a reasonable price? It's the only thing holding up my foglight install.
  • p0cket penguins
    • Jul 2008
    • 481
    bavauto.com
    • Sam Cogley
      • Jun 2008
      • 521
      I was hoping for something I could pick up at a local parts store...
      • Aptyp
        • 6584
        if you know the part number, your local stores can cross reference it.
        Especially Bosch numbers
        • StereoInstaller1
          GAS
          • 22679
          For foglights, you should see if you can find a SPST 5 pin relay. You will see 2 "87" terminals instead of an 87 a and an 87. Most Auto Parts stores have them.
          Closing SOON!
          Thanks for 10 years of fun!
          • Sam Cogley
            • Jun 2008
            • 521
            Problem is that the 30 and 86 terminals are reversed from standard on the orange BMW relays, and cross-referencing didn't turn anything up in AutoZone's computer or books. I tried removing the 87a terminal from a standard Bosch relay and it didn't work. They actually had an aftermarket relay without the 87a terminal (just four prongs), but 30 and 86 were still in the regular position.
            • DaveSmed
              • Apr 2007
              • 1406
              I can't think of anything else that uses that pin arrangement. That's why I usually scoop all of them up at the junkyard.
              Maybe check in a VW as well?
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
