Premium sound sounds like shit
  • SpartanTiger81
    • Sep 2007
    • 555
    So I just bought a 89 325is with premium sound and it sounds like complete shit. My old e just had stock sound and the quality was 100% better. I have some JVC head unit which actually isn't bad, but the speakers can't handle shit. My old car had a pioneer something and 2 coaxial pioneers in the rear. I thought preium would sound better, lol...
  • Danny
    • 14216
    I have a full stock system for sale.
    • SpartanTiger81
      • Sep 2007
      • 555
      I'll probably sell this head unit, buy 4 new coaxials and let that be it. I don't need much bass, but this all treble sounds like complete shit..
      • Danny
        • 14216
        Well if you have a headunit then play with the settings.
        • SpartanTiger81
          • Sep 2007
          • 555
          I did and it didn't do much.
          • StereoInstaller1
            GAS
            • 22679
            A properly installed Premium sound speaker system sounds pretty OK with an aftermarket deck.
            Closing SOON!
            Thanks for 10 years of fun!
            • SpartanTiger81
              • Sep 2007
              • 555
              For some reason my sounds like shit. I can't even turn it up to 20 before that shit has a like the crackling shitty sound.
              • NOMAD
                • Feb 2007
                • 1502
                You are probably running it through the stock amp and its crapping up the sound.
                Try running wires from headunit direct to speakers. Could be your speakers are also blown.
                Working Premium speakers don't sound that bad. On par with a basic coaxial setup.
                '74 2002 - Build blog at
                nomads2002.blogspot.com
                • StereoInstaller1
                  GAS
                  • 22679
                  Agreed, only better than most coaxials, and WAY better bass than 99% of the components out there.
                  Pull your deck out and look at the speaker wires. See if they are connected to the stock wiring. If they are, you might be running the stock amp still.
                  An easy way to test that would be to see if you can pull the plug on the amp.
                  IF YOUR STOCK AMP IS CONNECTED your caps lock might get stuck and your car will sound like shit.
                  Find out and let us know, OK?
                  Closing SOON!
                  • E30 Cabrio
                    • Oct 2006
                    • 1954
                    I just installed a new HU in my 88 with Premium sound, bypassed the factory amp and it was quite an improvement.
                    As mentioned, you're probably still wired to the factory amp.
                    Check the stock fader and see if that's connected and functional. That would indicate the factory amp is still connected, but not necessarily the opposite - if the fader doesn't work, it doesn't mean the stock amp is not connected, just that the fader was bypassed.
                    The stock front speakers and tweeters are decent, but the rear stock speakers on cabrio's are horrible.
                    I'm going to replace them soon.
                    1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
                    Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
                    Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
                    • aSpecD_
                      • Jul 2008
                      • 495
                      ok how else am i able to check if stock amp is still connected?
                      i just got a free sony headunit from a homie and wired it yesterday to my premium sound 89 325is. i don't have the fader thing though nor did i find any wires that would go to it. i connected everything according to e30 wiring diagram and the diagram of the head unit. i'm not getting any base and my rear speakers give me that crackling sound about volume 18..
                      stereoinstaller1, what do you think?
                      -jeff
                      best modification to any car is a clean car.
                      -jeff
                      • TurkE30
                        • 272
                        mine is all stock it sounds excellent even when i get it over 20...
                        • T Verdier
                          • Aug 2007
                          • 2636
                          bump
                          • T Verdier
                            • Aug 2007
                            • 2636
                            sorry where is the stock amp?
                            • De //m3
                              • 165
                              Stock amp should be in the trunk behind the lefthand (Driver's Side) paneling, just ahead and inboard of where the antenna mounts. At least thats where it is on an E30 M3. But I think it should be in the same spot.
                              2001 330i - In the garage.
                              1986 335is - 325e with Euro 735 M30B34, Under Construction.
                              1989 E30 ///M3 - Sold.
                              1975 2002 - Sold.
