electrical hell
  • lukem23
    • Mar 2008
    • 297
    electrical hell
    none of my dash lights work, including the heathing and AC buttons i have no idea what it could be. i checked the fuses and everything i could think of. Even trying to put in a head unit seems impossible. any with info that could help is very helpful.
    thanks
    luke
  • another1bitesthedust
    • 85
    oh, no install gone bad...... you might have yanked one of the conectors in the dash,,
    • lukem23
      • Mar 2008
      • 297
      the light didnt work before i tried to put in a head unit.the PO must have messed something up.
        • 85
        did it have a aftermarket unit there before??
        • lukem23
          • Mar 2008
          • 297
          yeah, the PO was a big time ricer. idk what he did or whats wrong with the car but its probably one of the most annoying things ever
            • 85
            check all the conections behind the head unit ,, i would bet he clipped a wire,, that is most of the problems that happen during installing,,, i have heard of all kind of stuff not working after a bad install, check all the wires ,, do you have power windows???
            • lukem23
              • Mar 2008
              • 297
              i do have power windows. and they do all work. i never thought of clipped wires.... there are some but i just figured that it was to factory radio or the PO's headunit
                • 85
                does the power window switch light up???
                  • 85
                  check power on those clipped wires with the lights on and off,, you should be able to find it pretty quick
                  • lukem23
                    • Mar 2008
                    • 297
                    ok, once i do find ones with power. then what? how to i know if they go to my dash or not?
                    • StereoInstaller1
                      GAS
                      • 22679
                      If your parking lights work, that means there is power to the switch.
                      Run the dimmer for the dash lights up and down, see if you get even a flicker of light.
                      Are you OK with electrical manuals? The manual for your car is online, the actual factory manual. It is kind of hidden in www.wedophones.com
                      Closing SOON!
                      Thanks for 10 years of fun!
                        • 85
                        color coded,,,, just match color,,, does any of the lights work at all???
                          • 85
                          i didnt even think about the dimmer,,,,+1
                          • lukem23
                            • Mar 2008
                            • 297
                            i tried before and it dosent make i difference. i will try again, thanks for the online manual link. i hope this could solve it
                            • lukem23
                              • Mar 2008
                              • 297
                              thats a crazy manual. i wish i could print it. it wont print right for me :(
