Half the cluster won't work
  • archemedes
    • 125
    My tach, and temp gauge are dead, lights all work, new batteries on a new si board. Are there any other common issues before I start tracing wires?
  • daniel
    • 6703
    maybe a dead fuse, check 10 and 21.
    http://instagram.com/dslovn.drives
    • optimusp517
      • Oct 2005
      • 797
      You want to definitely check the fuses first. I had the gas, rpm, and temp gauge go out and it was only a fuse. I've learned if any electrical goes out, check fuses first :)
      • archemedes
        • 125
        fuses are all good(I am an ASE certified mechanic so I know a few things lol)
        • xxx-Lost-Soul-xxx
          • Apr 2008
          • 1953
          You may be ASE,but do you know OLD BMW Fuse's?
          No disrespect,but ive met some pretty stupid ASE's tech's.
          do the easy thing first,swap clusters,after you have checked the fuse's.
          Im sure someone near you has a spare cluster to loan you.
          • archemedes
            • 125
            I test fuses not look at them (test light and multi meter have found many bad good looking fuses) I have swapped clusters, same issue. Grounds are good, looks like time to chase wiring
            • E30 Cabrio
              • Oct 2006
              • 1954
              SI board/batteries.
              1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
              Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
              Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
              • archemedes
                • 125
                Originally posted by E30 Cabrio
                SI board/batteries.
                both are new as stated in original post
                • Elliot
                  • Feb 2006
                  • 83
                  any news on this my tach is also dead!!
                  • k_wakasugi
                    • 214
                    Hmmm.... punch it?
                    • NickP
                      • 257
                      Longshot - Did you replace the batteries yourself? One side of the battery has 2 pegs going into the circuit board. Only 1 peg is "live", the other seems to be for strength. Make sure you connected the wiring / battery to the "live" peg.
                      • ethirtydavid
                        • Jan 2008
                        • 2331
                        i'm curious what the solution was
