SI Board
  • abepark
    • Feb 2006
    • 384
    SI Board
    are the SI boards Spossed to be covered in this red glue? its shiny and smooth and def solid, there are globs in between the batteries and 2 globs on some diodes. it doesn't look like the battery's have leaked they seem to be intact, and contacts look good
    Talking about cluster's theres a wire that's for cruise control that has multiple spots, now some one told me theres also a wire that goes in the connector for the speedo, is this correct or does the speedo get its signal through one of the big connectors? Last question there are two bulbs that slide into the cluster when its together what spots are they spossed to go in?
    Pictures would answer lots of my questions.
  • franco90
    • 3185
    I am lost
    I've always been proud of being a Marine.
    I won't hesitate to defend the Corps
    "Supersquad"
    ‎"Prostitutes are a sub-category of Amusement Parks"-
    • abepark
      • Feb 2006
      • 384
      the SI board that I have is covered in some kind of red stuff. almost like a sealer from water maybe? is that normal?
      • archemedes
        • 125
        anti corrosion stuff more than likely, also the batteries are glued together
        • Jean
          • 18228
          Normal.
          • abepark
            • Feb 2006
            • 384
            thanks.
