cluster question!!!
  • bimmer_E30
    • 5001
    cluster question!!!
    so ...i took the cluster out today to fix that funky coolant temp gauge and its great now!!! for the bad part my parking brake light is out???it used to work before i took the cluster out...also i still have a funky gas gauge!! the test!! i filled the car today with 20$ prem 91 gas before the fillup it was at less than 1/4 after the fillup it sat at 3/4 i drove the car today for a bit and i was getting about 9.2L/100kms(30 somthing MPG) not to mention that i was driving like a grandpa shifting at 2000rpm.or so after i went home i looked at the gauge and boom my gauge is sitting at the 1/4 mark?? am i loosing gas or whats going on?:???:
    thanks R3v.
    Originally posted by e30e
  • Hartge_H27
    • Jun 2006
    • 1699
    well 9.2 is like 25mpg. but anyway ur sending unit for the gauge could be bad. but the only way i know to check it is to pull the fuel pump out. as for the parking light u might have knocked the blub loose or it just blew. it is probaly the original blub to the car.
    • bimmer_E30
      • 5001
      shit...i will check again tommorwo.
      • bimmer_E30
        • 5001
        bump.. also i have some ebay cluster chrome rings that i want to install.. i was wondering how to take the plastic cover to put the chrome rings!
        • Hartge_H27
          • Jun 2006
          • 1699
          the plastic cover is glued on. so very carefully work it off and there u go.
          • lukem23
            • Mar 2008
            • 296
            i have a cluster question too. could a cluster it self be the cause of a fuse blowing?? i checked all of the wiring and its fine. but ever seince i put in a new cluster fuse 10 keeps blowing. fuse 10 is MPG gauge, tac, gas, temp and check.
            thanks
            • bimmer_E30
              • 5001
              thank you Sir!!! also any ideas if u know what kind of glue should i use;)
