Engine oil light
    Engine oil light
    on the indicator is on. This happened after changing my battery.... the oil is perfect though and it wont go out. checked the oil level sensor and relays just in case they creeped out or something but still nothing.
    its realy annoying! help.
    Originally posted by Lof8
    4 doors allow you to transport more whores.
    therefore, their value is much greater.
    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
    If you mean the overhead check panel, that is the oil level. There is a sender that can be cleaned out or replaced. As long as you manually check the level with the dipstick I wouldn't worry about it until you can get to the sender. If you mean the dashboard light, that is a low oil pressure indicator. Different can of beans there...
    Originally posted by chileelky
    amaze about the enthusiasm e30 generate
      its the over head, my pressure is good as is the level
      any other thoughts?
        sounds like a sensor
          it did give me a false reading a couple times recently
          what would make it go bad changing the battery tho... lame
            coincidence, key on when battery unhooked or hooked up can do things too
              Try unhooking your battery for half an hour or so.
