i'm going to be running 2 sets of rca wires to my trunk from the head unit. one set for my sub amp the other set for my speaker amp. can i run both sets in the same place/route or will that cause interference? thanks so much in advance...
quick general car audio question...
how are you suppsosed to run your wires i alsways just put everything on the same side and i dont seem to have a problemComment
ok, next stupid question:
i have never run more than one amp before. and i know i will be using a distibution block for the power. but can i use a distribution block for the ground as well? just ground one cable and then distribute the ground closer to the amps? it would keep me from having to run two ground wires...Comment
Yes you can.
I generally use something fused to run the power, then an unfused block for ground.
Keep in mind all of that shit is just jewelry though and does not improve performance.Comment
