173 ECU question
  • TOPSPEED
    • 42
    173 ECU question
    I have a chance to get a Conforti chip for really cheap! The problem though is that it's for a 173 ECU. My car has a 380.
    Can I just simply change my 380 for the 173 ECU? What are the differences in the two? I know the chip will not work in my comp hence why I am wondering if I can change the ECUs around.
  • Kilomph
    • Oct 2004
    • 599
    • TOPSPEED
      • 42
      Doesn't really answer my question though. Just shows another one for sale and a person with a similar problem/question.
      • Kilomph
        • Oct 2004
        • 599
        What I was trying to get across is that the 380 ECU supports 173 chips. Search feature is grrrrrrrrrreat.
        • James Crivellone
          Head Janitor
          • 6303
          153, 173, 380 and 524 ECU's are all compatible with each other (for the 2.5L M20 at least)
          • Kilomph
            • Oct 2004
            • 599
            Originally posted by MarkD
            There are such a small number of "153" DME's around that I didn't officially release a performance chip for it. Also, I consider the maps in the 173 and later DME's to be better.
            The DME's after the 153 also have more integration in them, all the circuits are on a single board and it should be more reliable.
            Try to find a used 173 or 380 DME, and use that. It's a direct drop-in.
            A 153 chip can be placed into a 173 ECU? Never knew that.
            • TOPSPEED
              • 42
              Great to hear ... thanks for the help guys!
              I will have a nicely chipped 325i soon :)
              Any info on Turner Motorsports chips? I already have the 17.5 M50 injectors and getting an M30 AFM installed soon as well. What should I expect?
