Removing aftermarket cellphone antenna from window
    You know, the kind that has something "stuck" on the inside of the window and a mount and antenna on the outside of the window - sandwiched if you will. This is for a rear window.
    Can I just razorblade the sucker off?
    89 325is track project / 05 x5 / 99 M3
    E30 stuff for sale | Parts I'm looking for
    They are held on by an adhesive. Razor blade scraper should be fine.
    1991 325ic and 1991 318is
