Uberground Negative cable 4-16HP gain!?!
  • Aerton
    • Oct 2006
    • 729
    I just came across this on eBay and found it interesting as a replacement for my ground cable but power gains???
    http://cgi.ebay.com/ebaymotors/1-BAT...Q5fCarQ5fParts
    KabelMann Uberground Negative cable
    Fully made In USA
    2ott/Double-Zero Gauge, 12mm thick fine-strand pure copper wire
    Heavy Butyl Rubber casing with anti-moisture inner layer Tin-coated alloy ends, corrosion resistant.
    Triple hex-crimped at each end= maximum contact area
    Weather-protected heat-shrink wrapped connections
    Great upgrade to Porsche electrical systems
    4-16HP gain due to less Alternator load
    and increased ignition spark energy
    greatly lowered circuits resistance
    Noticeable overall improvement in
    electrical functions and driveability
    Increased conductivity= much lowered resistance
    through vehicle electrical circuits
    provides less alternator load, more ignition spark energy
    Alternators take up to 24 HP while engine running
    Starter cranks stronger, better starting moments
    Extended life of alternator, battery, starter, coils, other components
    Wipers, power windows, lights, stereo radio, etc. work better
    especially on older classic vehicles
    All USA made components assembled in CA
    UL approved: UL STD.486A
    Performance enhancements usually cost $25-40 per HP
    KabelMann Battery Uber-Ground Cables
    improve overall running as well
    Fitted and tested on over 160 customer's cars
    Some in use >9yrs.
    We have a 15" model in another ebay listing as well
    measure your cable if you have a non-stock set-up
    [ie Optima, relocated battery, etc.]
    5-10 minute installation
    Retail for US$40+
    KabelMann UberGround exclusive Hard to find this level of performance & quality
    at this introductory pricing
    before distribution network kicks in
    WTB-Strut Bar
  • M5wanaB
    • Aug 2007
    • 405
    these work really well with snake oil and electric superchargers.
    1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
    • george graves
      • 20003
      It's said that some hondas this actually helps a tiny bit. It's been cover on here before. I think it's called "upgrading the big three" or something like that. Don't bother with it for our cars. Just make sure you have a good ground strap to your block, and your battery terminals are clean.
      Originally posted by Matt-B
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        Aaaaahhhhchoo...................Sorry i am allergic to bullshit
        -Andy
        • DCColegrove
          • 2748
          That is some silly crap...
          It's true that an alternator can grab up a lot of HP and ECUs work better with clean current.
          But if more grounds does help... There was something wrong in the first place.
          Add this to the list with: Magnets on the fuel line, A resistor in the Temp sensor circuit, and a Propeller in the induction boot.
          • Axxe
            • Aug 2004
            • 3355
            Oh boy. Where do I start?
            Keep it slideways!!
            • rwh11385
              lance_entities
              • 18403
              A true R3V classic thread. Back when we flamed people for trying to sell snake oils instead of making them a Site Sponsor.
              • KevlarWeave
                • Jun 2008
                • 141
                I hate all the silly stuff people try to sell. Extra grounds?
                "The fabric of safety, drowned in resin..." - KevlarWeave
                • Aerton
                  • Oct 2006
                  • 729
                  Originally posted by rwh11385
                  http://www.r3vlimited.com/board/show...ght=ground+kit
                  Thanks, interesting thread, I was curious about these grounding kits.
                  I made my own on two previous cars, the Jetta came back to life after a couple of ground wires and the e30 325e was no better for it. I understand that cars have ground straps in place but if you have corrosion in the 21 ear old original straps there might be some benefit from new ground cables. I will not spend $150 on a set when you can buy 0 gauge cables and connectors for under $20 bucks. I was looking to replace the battery ground cable in my car as it is not the original and it looks like crap when I found this Uber ground.
                  WTB-Strut Bar
                  • KevlarWeave
                    • Jun 2008
                    • 141
                    I think it's always good to grind the surface down to bare metal where the anchor points for the DIY groundstraps. After, a good method for anticorosion protection is using that funny red battery spray in a can.
                    • SpecM
                      • Oct 2005
                      • 4531
                      that stuff smells terrable but it works
                      1989 cirrisblau-metallic 325i
                      • StereoInstaller1
                        GAS
                        • 22679
                        Big wires=sex
                        No better performance, but sexy as hell.
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • DCColegrove
                          • 2748
                          Ya' think that was aimed at me?
