any1 ever make a cmoy amplifier?
  • Unearth078
    • May 2008
    • 2623
    i was curious, every schematic i look up i cant find that ic chip needed...
    Originally posted by Lof8
    4 doors allow you to transport more whores.
    therefore, their value is much greater.
    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
  • kronus
    • Apr 2008
    • 13028
    My friend has made a few amps... I think he may have started with a CMOY. What chip are you missing?
    cars beep boop
    • chris4891
      • 51
      thats probably because in theory you can use any op amp, though there are quite a lot of opinions as to which sound the best.. ive dabbled in this before, tangent has a pretty good cmoy tutorial. theres a section on op amp selection under 'parts list and suggestions' - http://tangentsoft.net/audio/cmoy-tutorial/
      also, check out the diy section at head-fi.org
      • Unearth078
        • May 2008
        • 2623
        ive tried quite a few differnt schematics none of which the op amp is stocked by mcm electronics
        • kronus
          • Apr 2008
          • 13028
          Search on Digikey, they probably have a better selection.
          cars beep boop
          • Unearth078
            • May 2008
            • 2623
            thats the place my electronics teacher used to order his junk from! sweet
            • chris4891
              • 51
              yeah, i usually go with either digikey, mouser, or parts express depending
              • Unearth078
                • May 2008
                • 2623
                werw
                common ground is chasis correct?
