need some help, bad ground?
  • Unearth078
    • May 2008
    • 2623
    The car wont start. Basically for a split second power will make it to the starter but not enough to actually turn the car over. figured it was my starter so i swapped it. still same effect with the "good" starter. i noticed after that split second, which is why i believe it is a bad ground, the oil engine level sensor harness started to smoke. oddly enough the oil level light went on a few days before this occurred. looks as if it is the ground in that harness had a bit flowing through it. looks as if oil pan to chassis ground is nice and secure, what other grounds should i check? any ideas?
    any help would be much appreciated
    Originally posted by Lof8
    4 doors allow you to transport more whores.
    therefore, their value is much greater.
    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
  • kronus
    • Apr 2008
    • 13029
    Unplug your alternator charge lead, jump the battery, and try to start.
    Something similar has happened to me, where the alternator was shorting through when trying to start.
    cars beep boop
    • Unearth078
      • May 2008
      • 2623
      wow, kronus, started right up, New alternator fixed it huh?
      • kronus
        • Apr 2008
        • 13029
        Err... we fixed it by whacking the old alternator with a wrench a couple times.
        You need to rebuild the alt. Brushes, diode. There might be a DIY somewhere here, it's easy enough to do yourself.
        cars beep boop
        • kronus
          • Apr 2008
          • 13029
          Here is my thread where we dealt with the problem.
          cars beep boop
          • Unearth078
            • May 2008
            • 2623
            thanks a ton
            i really appreciate it =) sorry you had a similar problem tho, i thought id never get this one squared away
            • Unearth078
              • May 2008
              • 2623
              dfgd
              mm i may have spoke too soon put a new alternator in and seems to be the same issue. hoping its just a drained battery but my DMM died so ill be replacing the battery then checking it
              • Unearth078
                • May 2008
                • 2623
                send me a 9v battery?
