If you can find a way to make the splines work and find a way to line up the turn signal repeat cancel pin, you should be good to go. Jordan did this over on emotech awhile ago; you might want to search over there. He did it with an e46 wheel though iirc.
He's done it with 2 wheels - and I'd probably try to get him to help me with mine.
Beyond the wheel fitment, it should be easy to get the controls working...there are a couple of pieces made by PAC, depends on the brand deck you have/get...most likely it will be either a swi-jack or a swi-ps. Can be a little tricky to program, but it's pretty self-explanatory. Worst case scenario a swi-x would work too, no matter the deck (as long the deck will work with a wireless remote and your car isn't a vert).
You can look through them uuuuuuh here if you want.
Reason: added link
92 325ic 5 speed, hard top, windscreen, 133k, for sale sigpic
Turf my head unit has these capabilities and I have begun making my non-used cc stalk in to a radio controller. Forward and back are to change track/station and up/down are for volume. So far I've gotten half of it to work, but i have abandoned the project until I get my body work and paint finished.
It will work for sure if the head unit is compatible with the car your wheel is from.
