Megasquirt and LE-Jetronic
  • ehrnst
    • 15
    Hi.
    I am currently trying to wire MS up in my m20b23 turbo. i am planning to build the MS in to the OEM LE-Jetronic case, and i am wondering if any of you have done it or somthing similar.
    The oem ECU has got 25 pins, but the harness it self only got 14, the rest is blanks.
    Since i wan't to use "all" factory wiring trough the contact i was wondering if there was any wires i could ditch an use for the MS instead.
    So the ideal would be a refrence sheme over the LE-Jetronic pins and the MS' DB37
    PS:
    My car is already running MS with 88+ 60-2 generic wheel and VR sensor.
    Running the stock distributor with locked weights, and blocked vaccum advancing.
    sorry for my english, and possible very bad spelling
    Thanx
  • tn325i
    • 1154
    Click rs4pro3 He has done numerous stock ecu cased Megasquirt setups.
    • Jean
      • 18228
      Your english is fine btw!
      • ehrnst
        • 15
        looks like i have figured it out now.
        found some scheme of the old le-jetronic. Now its time to figure out what wires i can cut and use for my 60-2, lambda etc
        to be continued
        • babisbabou
          • 1
          Any pictures of the set up available man?
          I have a home made turbo set up for my M30B28 and need some help, distributor etc some advice?
