Pioneer Stereo system.
  • e30this
    • 3580
    Ok So Im looking into getting a system for the e30. Nothing big, loud or huge.
    Just a little bump.
    So I was looking around and I came up with this.
    Pioneer TS-W258D4 for the sub
    Pioneer GM-6300F for the amp
    Pioneer DEH-P6000UB for the deck.
    What do you guys this about this setup?
  • StereoInstaller1
    GAS
    • 22679
    Shit. ANOTHER PM I forgot to answer...
    OK, the woofer is DVC, and they do not make that woofer in SVC. The issue here is that the amp will not be happy seeing a 2 ohm load, nor will it be making its best power on a 8 ohm load...solution? Either add a second amp ( like the D-7400M) that is intended for a 2 ohm load or use a different woofer.
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • e30this
      • 3580
      What woofer do you suggest? You tell me what 3 pieces will work best together and I will buy.
      You know your shit more then me, So I will feel better listening to you.
      • StereoInstaller1
        GAS
        • 22679
        Do we have to stay with pioneer? Their amps aren't the best...
        Closing SOON!
        • e30this
          • 3580
          Nope, Dont have to. You pick out anything you want, From the deck, amp and sub.
          Whatever you think are the BEST 3 things put together.
          Then I will add 4 new speakers later on with a set of tweeters. You pick my system, I buy.
          • StereoInstaller1
            GAS
            • 22679
            Deck: Pioneer is great, IMO. I have a DEH-P5000 in my dash now, gonna swap to a DEH-P710BT or whatever the hell it is called because I want bluetooth.
            Sub/speakers/amps, how about Memphis? more good chinese shit, basically, but they make a "Power Reference" series amp that is good and cheap. They also make a DVC 2 ohm per coil woofer, so you can start off with the woofer in 4 ohm, use half of a 4 channel amp to run it, then later, add a 1 ohm mono (class D) amp to run it, then use the 4 channel to run the mids and highs only...upgradeability, see?
            Woofer: M310D2
            4 Channel amp:16-PR4.50
            Sub amp: 16-PR1.500 or 16-PR1.1000 (overkill!)
            I love their mids and highs, like the 15-MCS5.
            See if you can find a decent price on them, GL!
            Luke
            Closing SOON!
            • e30this
              • 3580
              Thanks for all the help Luke. I will be looking into getting everything when I get back in town.
              I will post up when things arrive and go from there.
              • Mless5
                • Jul 2006
                • 817
                Sonix has a very shitty customer service/support/warranty.
                '96 328is
                '97 m3
                '04 zhp
