dont read this... i promise
  • robert325is
    • Aug 2004
    • 1171
    how do i attach my wires to the headunit?
    • robert325is
      • Aug 2004
      • 1171
      could anyone put up some pics of how they have their wires run.. because this would help out a bunch
      • BMW BMXER
        • 2325
        Sold it.
        • colt325e
          • 228
          Thats the hard part. Well not really hard, just sorta time consuming.
          • robert325is
            • Aug 2004
            • 1171
            i have everything all wired up now... i just need to figure out how to get to my source wire for the head unit.. is the best way just to pull out the whole HU assembly?
            • colt325e
              • 228
              What do you mean Source wire?
              • robert325is
                • Aug 2004
                • 1171
                the RCA cable.. the one that goes from the HU to the amp
                • colt325e
                  • 228
                  yeah pull it out. My RCAs are run on my passenger side from the trunk through some hole at the bottom of the rear seat (when its taken out) along the door (under the carpet) and behind the glove box. There are other ways too.
                  • robert325is
                    • Aug 2004
                    • 1171
                    i ran mine from the drivers side of the car under the dash b/c thats the way the speaker wires were run when whoever installed the HU wired up the speakers... how do i pull out the HU?
                    • colt325e
                      • 228
                      There are these metal clip type things that are pushed up on the tops and sides of the main case that need to be pushed down and then it will slide right out. It takes a while and can be frustrating to get right. but...
                      • DSchultz325e
                        • Aug 2004
                        • 1158
                        i think, depending on the install, you might also have a couple bolts to deal with on the sides. if it doesn't come out of the brackets very easily, take off the trim panel connected to the steering wheel and pull out the obc and see if there aren't bolts. i had to have my eclipse deck installed by the dealer to be covered by warranty and i haven't removed it, but when i took out my cluster i was pretty sure they had it bolted in. i dunno, hopefully it won't be too hard.
                        I retired my E30 for now...
                        E46 323i
                        David Schultz
                        • robert325is
                          • Aug 2004
                          • 1171
                          BUMP
                          ok i've finally gotten around to doing this, where exactly does the RCA cable hook to my headunit i need help ASAP b/c i need to be be somewhere in 1 hr and all i have left to do is hook up the RCA cable to my headunit
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            you plug them into the pre-amp inputs on your aftermarket deck
                            Originally posted by Gruelius
                            • robert325is
                              • Aug 2004
                              • 1171
                              ok i got it.. yah i dint know where the hookups were b/c the book i got from the PO didnt say anyhting about the hookup points and there were no markings on the HU so i guessed one and it turned out to be the right one...
                              thanks for all the help it sounds great
