power wire and fuse question for 2 amps
  • hugh jass
    • 2220
    I'm starting to get supplies for a stereo for my e28 m5. i'm planning on running a jl 250/1 amp for the sub and a nakamichi pa304 (4x45) for the speakers. any input as to what size power wire and fuse i should run to the distribution block and then what size power wire to the amps? i don't have any manuals for either amp and don't want to undersize anything.
    thanks.
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
  • kronus
    • Apr 2008
    • 13028
    Have some tables.
    cars beep boop
    • hugh jass
      • 2220
      thanks!
      so 4 gauge to the dist block and than 8 gauge to the amps is enough? and a 96 amp fuse or something close to it?
      just want someone to verify this...
      • hugh jass
        • 2220
        oh, and separate fuses or no?
        • DrMcDave
          • 1793
          i'd use a fuse before each amp after the dist block.
          • Mless5
            • Jul 2006
            • 817
            Fuse main wire right next to batt, run it to fused distro block in the trunk, 4 ga to amps if you can fit it in.
            '96 328is
            '97 m3
            '04 zhp
