Gauge cluster keeps blowing the fuse.
  • Asbradley21
    • Jun 2008
    • 1938
    Any ideas?
    S54B32 swap in progress. Status: Getting There
  • abepark
    • Feb 2006
    • 384
    have you touched your OBC or euro clock wiring ?
    • E30SPDFRK
      • 5715
      10 or 21?
      Byron
      Leichtbau
      • Asbradley21
        • Jun 2008
        • 1938
        No wiring has been touched.
        10
        • Asbradley21
          • Jun 2008
          • 1938
          Morning bump.
          • einstein57
            • Jun 2007
            • 10780
            Is that the same fuse as the back up lights? If so check to see if there is a wire dragging on the drive shaft
            www.gecoils.com
            • Asbradley21
              • Jun 2008
              • 1938
              Just checked and it appears that the reverse lights don't work. So I'll check for that wire.
              Thanks!
              • project325ese
                • 48
                Did you find anything?
                • Asbradley21
                  • Jun 2008
                  • 1938
                  Not a thing. No wire, nothing.
                  • ethirtydavid
                    • Jan 2008
                    • 2331
                    just to verify this just started happening out of the blue? been working on any part of your car recently?
                    you have probably already looked at this:
                    • Asbradley21
                      • Jun 2008
                      • 1938
                      Pretty much out of the blue. Happened after an autocross run. Before that, the brakes were fucked up and the pedal wouldn't return, then that fixed itself, then the fuse blew. I put a new fuse it, it blew within the next day.
                      • Julien
                        • 7471
                        yeah, but check the reverse wire as it passes from the inside of the cabin to the tranny tunnel, mine was grounding itself there
                        Build Threads:
                        • Asbradley21
                          • Jun 2008
                          • 1938
                          Thats what it turned out to be, I just disconnected it for now. I seriously don't care enough about my reverse lights to bother. I'll get to it eventually I'm sure though.
