How to wire up the antenna wire to the rear defroster
  • p0cket penguins
    • Jul 2008
    • 481
    Hey guys,
    I was wondering how to wire up the antenna to the rear defrosters? I know I would have to disable the rear defroster.
    Thanks
    Chris
  • StereoInstaller1
    GAS
    • 22679
    Find an E36 in a junkyard, pull the antenna module (upper left rear pillar) and install it.
    As you pull it, it will make sense how it works.
    I might do that on mine so i can have MSNDirect on my AVIC-F500BT, in my quest for not having a radio at all...
    Closing SOON!
    Thanks for 10 years of fun!
    • p0cket penguins
      • Jul 2008
      • 481
      do you happen to have a part number for this guy?
      http://www.realoem.com/bmw/showparts...98&hg=65&fg=30
      http://www.realoem.com/bmw/showparts...49&hg=65&fg=30
      Also if anyone can answer my original question that would be wonderful. :) it would just make it so easy.
      • p0cket penguins
        • Jul 2008
        • 481
        has anyone used this
        http://cgi.ebay.com/ebaymotors/Hidde...QQcmdZViewItem
        • StereoInstaller1
          GAS
          • 22679
          I use those on boats.
          On your defroster antenna, you can simply disconnect the defroster and connect the center lead of the antenna, but you are gonna have pretty weak performance.
          Get the E36 module. Once you find one, it will all make sense.
          Closing SOON!
          • p0cket penguins
            • Jul 2008
            • 481
            to the junk yard i must go..... or can i get a regular antenna and then just lay it across the back windshield
            • 240zs30
              • 583
              Please post results. I have been trying to find a solution since I shaved mine. I don't listen to much radio but every once in awhile I would like to be able to at least tune stations.
              • Schnitzer318is
                • Jan 2008
                • 2057
                Originally posted by p0cket penguins
                Going to try one of these as soon as my antenna is shaved. Though I'm just going to use a universal jobbie to plug into the aftermarket head unit.
                "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                91 318is Turbo Sold
                87 325 Daily driver Sold
                06 4.8is X5
                06 Mtec X3
                05 4.4i X5 Sold
                92 325ic Sold & Re-purchased
                90 325i Sold
                97 328is Sold
                01 323ci Sold
                92 325i Sold
                83 528e Totaled
                98 328i Sold
                93 325i Sold
                • dude8383
                  • Jan 2005
                  • 10387
                  make sure to snap some pics. i want to get rid of my antenna hole.
                  • p0cket penguins
                    • Jul 2008
                    • 481
                    ill post up pictures tonight... but what i did was purchase a universal rubber antenna with a mount for the e30 style hole and a plug cap thing from ace hardware (can be found in those drawers next to all the bolts). I then took apart the antenna and took that brass looking piece where the antenna cable plugs into. I removed that from the antenna and plugged the banana plug clip styled plug from the universal rubber antenna, after I removed all the extra mounting crap on it. I wrapped both the connection from the brasslooking thing to the banana plug in electrical tape and zip tied it to a bracket. Then all I did was plug up the hole and since my track prepped e30 is stripped in the rear caged portion i ziptied the rubber antenna to the sheet metal thats under the door panel right behind the rear driver window. (I would have put it by the rear shelf but I couldnt get past the fixed back seats and in the caged area.) I still get great reception even in my garage. Ill have pics by tonight. Also the plug fits really really tight.
                    • p0cket penguins
                      • Jul 2008
                      • 481
                      • straight6pwr
                        • Sep 2004
                        • 3450
                        where did you mount the univeral antenna? or is it inside? link to product?
                        • accident
                          • 7303
                          luke knows all
                          Moral of this story?
                          • p0cket penguins
                            • Jul 2008
                            • 481
                            see the two zipties in the picture with the orange cage... its a little rubber universal antenna.
                            http://www.autozone.com/autozone/cat...questid=352680
                            • straight6pwr
                              • Sep 2004
                              • 3450
                              i gotcha, i thought that was wiring.
