E30 speedometer blown resistor
  • rwtags
    • Aug 2018
    • 208
    I blew a resistor in my speedometer, It stopped working right after I reflowed all the connectors on the c2 plug tryi g to fix a fuel guage issue.
    what would cause the resistors to blow? Taking it back apart I noticed that you could either have the speedometer plug having the missing pin on the bottom of the cluster or the top. I can plug it in either way but I am now not sure which is right.
  • Bmjpv
    • Mar 2007
    • 561
    My speedo had the same problem , 91’ 325ix . Car had been just sitting around , started & moved over (2) years . By itself the speedo would go straight to 110mph when the key turned on . Replaced the VDO board with used parts & all good !
    • rwtags
      • Aug 2018
      • 208
      i will see if i can find a picture, but you can either have one prong above or below, the cluster circuit board is not keyed, and i think that is 100% what blew the circuit board on the speedometer
      • rwtags
        • Aug 2018
        • 208
        So it was caused by me incorrectly connecting the speedometer to the cluster board, here is both possibilities, both were able to be screwed together, none the wiser to me...
        and
        I believe the blank pin on the bottom is the correct way to install it, if you install it incorrectly you will have no speedometer, and odometer, or trip meter.
