New Battery, no start?
  • Lazr111
    • May 2007
    • 340
    Ok, I recently got a new battery because my old one wasn't holding a charge... With the new battery, my car still doesn't want to start. I'm getting 9.5-9.8V with ignition on, engine off, and the starter just won't turn. If I jump it, it will start, but it seems slow. I'm just looking for what the culprit might be, and what I need to fix/replace.
    TIA
    If life passes you by... Downshift.
  • AndrewBird
    The Mad Scientist
    • 11898
    You are only getting 9.5V from your battery? Should be AT LEAST 12V.
    • E30 Cabrio
      • Oct 2006
      • 1954
      Check the ground for rust or fraying.
      1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
      Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
      Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
      • Lazr111
        • May 2007
        • 340
        I'm getting 9.5V with the engine off, around 13.3V with the engine on. The ground strap is starting to fray a little bit, so I'll see if I can find another.
        • kommissar
          • Dec 2005
          • 402
          Dude, you already posted this here: http://r3vlimited.com/board/showthread.php?t=134504
          • Lazr111
            • May 2007
            • 340
            I know... that was a repost for visibility...
            • Liam
              • 753
              See your other thread.
              I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
              • Lazr111
                • May 2007
                • 340
                Ok, so I replaced the ground strap, and it seems to have helped, but not alleviate the problem. I'm gonna have it tested next chance i get, so we'll see...
                • slo325i
                  • 417
                  I would replace the battery terminals too. I wasted a good battery cuz of this. Just a reminder....
                  '89 325i - Totaled... good bye my love...
                  '87 327i budget stroker - SOLD!!!
                  '92 240sx - ca18det powered drift toy - SOLD!!!
                  '89 325i - coupe - NEW daily
                  '96 Audi A6 Quattro- Grocery getter/baby hauler
                  '99 Busa - weekend wheelie monster
                  • Liam
                    • 753
                    Check all of the connections...
                    When you get a voltage drop it will cause all manner of hell down the path, the connections will get electrolysis corrosion and will actually loosen up from thermal stress caused by resistance in the circuit.
                    • Lazr111
                      • May 2007
                      • 340
                      Ok, back from the dead.
                      Battery was tested, Group 48. It tested perfect.
                      Tightened as many connections as I could find, and no luck.
                      What now?
                      BTW, thanks a ton guys
                      • e30_kidd
                        • Apr 2009
                        • 89
                        Originally posted by lazr111
                        ok, back from the dead.
                        Battery was tested, group 48. It tested perfect.
                        Tightened as many connections as i could find, and no luck.
                        What now?
                        Btw, thanks a ton guys
                        check the belt
