Mounting spots for front crossover box.
  • Axxe
    • Aug 2004
    • 3355
    Where do you guys mount your crossovers boxes for components? In the trunk or in the doors? I don't see a spot in the door to mount them. Thanks in advance.
    Keep it slideways!!
  • kencopperwheat
    King of Kegstands
    • 14396
    Install them where ever you'd like to. There isn't really much room up front, but I helped Brent (bhadole) install a set of components and we screwed them into the kickpanels.
    Mine are in the trunk (which requires a lot more speaker cable):
    Originally posted by Gruelius
    • Mystikal
      Wheel Fitment Expert
      • 9602
      My driver's one is up underneath the steering column, and the other is in the passenger kickpanel.
      • Axxe
        • Aug 2004
        • 3355
        I ended up using double-sided tape, and mounting it to the bosch unit on the driver side (nice flat surface) and in the glovebox on the passenger side. Only have the fronts in, but even just running off the deck (CDA-9831) I am really happy. Nice to finally have the ability to play CD's!
        Keep it slideways!!
        • Axxe
          • Aug 2004
          • 3355
          Before I forget, can the remote turn-on wire turn on more than one amp?
          Keep it slideways!!
          • DSchultz325e
            • Aug 2004
            • 1158
            yes. split it up and run it to two.
            I retired my E30 for now...
            E46 323i
            David Schultz
            • Axxe
              • Aug 2004
              • 3355
              That's what I thought. Thanks.
              Keep it slideways!!
              • christophbmw
                • Mar 2004
                • 363
                i just droped my crossovers under the front speakers. and (i know you didnt ask) but the rear crossovers fit perfectly under the rear dash. (well most of them do).
                '91 318is
                • DrMcDave
                  • 1793
                  i ran one wire to one amp, and then from that amp to the other, instead of splitting the wire.
                  • 808BMW
                    • 2910
                    My driver's side is crammed up in the knee bolster, theres lots of room up there. Passenger side is up in the dash too, I just pushed em in wherever there was room :P
                    • colt325e
                      • 228
                      sounds kinda ghetto
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        sounds kinda ghetto
                        For the remote cable? Who in the hell runs two of them from the deck? You just run it to one of them and then out of the first amp into the second one.
                        • colt325e
                          • 228
                          It sounded to me like he was saying run one wire and then split it in two; and have half go to one amp and half go to another.
                          • 808BMW
                            • 2910
                            If you wanna get anal about it, run the remote wire from the HU to a relay in the trunk, and use the relay to turn your shizzle on.
                            • DSchultz325e
                              • Aug 2004
                              • 1158
                              sounds kinda ghetto
                              thats what i meant, just tried to be succinct. your pic shows it clearly.
                              E46 323i
                              David Schultz
