Hardtop vinyl reattachment
  • mlbryant8
    • Jul 2014
    • 237
    Have a couple of spots on my hardtop where the vinyl is loose. Anyone successfully re-glue their vinyl?
    2007 X3
    1992 M Tech Cabrio
    1988 Cabrio - sold
    2001 X5 - sold
    1997 e36 328 - gave to son
  • flyboyx
    • 8371
    at the scallop behind the rear quarter window? they all pretty much do that when exposed to hot temps for any period of time. mine is loose there a bit too. someone posted here that they tried using a heat gun. i remember reading that they melted the vinyl a bit. i can't imagine how that would possibly work anyway. the material is under tension and wants to be flat.
    i was thinking about taking the top off the car, setting it on its side, getting a syringe, filling it with some kind of adhesive, and injecting it in the area. i think one would need to make a mold that conforms to that area of the top and clamp it there for a few hours while it dries.
    Gigitty Gigitty!!!!
    • mlbryant8
      • Jul 2014
      • 237
      mine is loose at the driver's corner near the mounting pin. Easy access just don't know if there is a particular product that others have tried successfully.
      2007 X3
      1992 M Tech Cabrio
      1988 Cabrio - sold
      2001 X5 - sold
      • GT BMW E30
        • Nov 2008
        • 2491
        That was me. I used the heat gun to soften up the material so I can get it to fit those contoured side areas. It worked good but I left heat gun pointed at a section to long as I ran the putty knife on the material. I saw that Napa and Advance Auto sells a syringe filled with glue. I never bought it. I have tried contact cement and heavy duty 3m spray. Neither worked for me.
        I have been looking for some fabric to redo mine.
        • flyboyx
          • 8371
          At this point, you might be better off painting it your body color.
          Gigitty Gigitty!!!!
          • JWHIII
            • Jan 2014
            • 104
            The syringe filled with glue sounds like a good idea. My top isn't too bad yet so I'm going to hold off until either someone else tries it first or my top gets a lot worse.
            • DRTSRFR
              • May 2008
              • 1836
              The problem is that your trying to re-glue an area that can't be cleaned, and throwing glue on top of old glue that's already compromised.
              Suspension tips here...
              http://www.r3vlimited.com/board/album.php?albumid=757
              • mlbryant8
                • Jul 2014
                • 237
                I can clean the area where my vinyl is loose so I am assuming that any glue for vinyl would work?
                2007 X3
                1992 M Tech Cabrio
                1988 Cabrio - sold
                2001 X5 - sold
                • DRTSRFR
                  • May 2008
                  • 1836
                  It will as long as the surfaces are clean.
                  I use 3m vinyl top adhesive. I believe it has better resistance to heat.
                  My experience isn't from doing the top covering itself. I had a saggy headliner, and attempted to glue it a few times with little success. I finally pulled up one side and took a stiff brush to the inside of the top which removed most of the old glue, blew it out with compressed air and re-attached. It's been holding strong for 3 years now.
                  • Gingerrella
                    • Jul 2014
                    • 117
                    I'm planning on taking mine off and color matching it also. If possible, I'll try and save the vinyl when I do it, in case any of you want a new piece. But as other people already stated, mine is not bonded around the scalloped edges anymore either.
                    Sent from my SAMSUNG-SM-N910A using Tapatalk
                    • GT BMW E30
                      • Nov 2008
                      • 2491
                      What do you guys think about recovering hardtop in same material as softtop?
