redoing hardtop headliner
  • ///M42 sport
    • 3952
    I was told by interior shop that the headliner needs to have a foam backing. Not sure if this was true of the OEM which seems to lay directly on the fiberglass. Anyone have input?
  • White325is
    • Oct 2006
    • 5947
    I used the foam backing. it was 8.00 a yard I believe. I did it all in one piece. if I were to do it again I would have made the section under the rear window its own piece. only reason why is because in the lower corners the fabric pulled away from the foam.
    The fiberglass panel isn't smooth enough to use a non foam backed fabric with out showing imperfections.
    • ///M42 sport
      • 3952
      any pics?
      • MC Hammered
        • Jul 2008
        • 2076
        Get it with foam backing as the material will lay down better and glue will not seep through the fabric.
        I got my material and spray glue from www.yourautotrim.com
        My 1989 e30 s52 Touring... this is Betty
        My 1989 325i vert (sold)...this is Nina
        My 1991 M5 (sold)... this is Veronica
        Photo comparison: OEM vs aftermarket windscreen for a convertible
        • Cha Ching
          • 1668
          What White325is & MCHammered said. There is a thin foam backing behind your oem headliner. It usually ends up stuck to the hardtop if your headliner starts to pull away. If you redo yours, or if you have sag, you need to scrape all the isht off before laying down your glue.
          • fight4life28
            • Apr 2014
            • 821
            Thanks for the info guys, I am in the same boat about replacing the headliner, go oem color or black?
            • MC Hammered
              • Jul 2008
              • 2076
              Go black as it looks so much nicer than the beige.
              • Cha Ching
                • 1668
                I went OEM (light grey) and it looks tits.
                • ///M42 sport
                  • 3952
                  I was thinking vinyl lotus? or is that not a good idea?
                  • mr2peak
                    • 2388
                    Try it. Could look really nice matched to the interior. Just be sure the color actually matches.
                    Drive it hard. Maintain it well.
                    A Topless Memorandum
