my top is in really good shape and doesn't leak as far as I can tell. I've only owned the car for a month.
When driving I can hear some wind noise from the rear. As if the top can sit tighter on the seal on the drivers side rear. Is there a way to adjust?
Also, the drivers door window, when fully up, rubs the top causing a wear mark and a poor seal. I roll the window down 1-2mm and it is fine. I believe there is an adjustment for this. Do I need to remove the door card to adjust this? how is this done?
thank you,
-Angelo
thank you,
-Angelo
