Hardtop lift questions
  • elDizzle
    • Dec 2015
    • 111
    I have a lift similar to this:
    I get that the cross bar goes through and under, but how do I slip the rear strap under the back part of the hardtop while it's still on the car?
    It doesn't feel like a one-man job, as I still need an assist to partially lift the top. It needs to be attached to the cross bar to balance the weight of the hardtop.
    Having a derp moment. Ugh.
    92 325i Calypsorot Convertible
    H&R Sport Springs+HD Billies+E90 Drop Hats
  • Das Delfin
    • Sep 2014
    • 2293
    Use the hoist to partially lift the top then hold the rear while you bring the center strap around and attach it to the cross bar. Then tighten and level
    Thought I thought hoists like this created bends in the top over time?
    • JWHIII
      • Jan 2014
      • 104
      I was seriously considering a hoist similar to this but got nervous that the heat in my garage plus the hoist lift points may cause the top to warp.
