E30 convertible suspension
  • Fasteddie222
    • Feb 2015
    • 230
    Quick question guys.
    I bought bilstein sport shocks with tokico springs for my e30 vert. I thought verts had the same suspension as the coupe but now I am reading online that the vert has different springs.
    I bought the suspension because it's pretty new less than 2k miles on them
    Now I'm a little worried the suspension won't fit right and my new wheels won't fit they are esm 17x8.5 offset 20 tires are 215/40/17
    Can anyone chime in some information
  • Das Delfin
    • Sep 2014
    • 2293
    the rear springs have a higher spring rate to compensate for the heavier rear end
    • Fasteddie222
      • Feb 2015
      • 230
      So what will happen if I run the springs from a coupe on a convertible?
      • N2MYE30
        • Oct 2007
        • 5536
        The back may sag a bit more compared to cabrio specific springs. I would put them on anyway to see where it sits. I ve seen so many setups that it is almost car specific. I can tell you what I have and most likely wont sit exactly like mine. Its a good thing that springs can be swapped out in a matter of a few minutes.
        COTM
        • Ether-D
          • Sep 2011
          • 2838
          I believe that both front and rear springs are of a higher rate in verts. I used vert front springs to lift a non-vertible. If you put hard top lowering springs on a vert, it'll just sit a bit lower.
          Originally posted by Andy.B
          I was born on 3/25…
