Trying to check with some of you more experienced people to make sure I have my work list straight.
1991 318iC
Things already done:
-PO did all the little shocks (trunk, top lid, seats)
-PO also fixed the odo gears.
-Tie rods are decent
-I've done the CABs/arms/front end links
-Full cooling system refresh
-All fluids
-New Brakes, wheels and tires
-Steering guibo
-Drivetrain guibo
Things pending:
-Motor and transmission mounts on the way
-x brace pending install
Things next:
-struts / springs / mounts
-rear bushing refresh
-rear axle seal
-tackle the timing seals over the winter (mild leak from that area)
Is there anything I'm missing? My door windows are out of alignment and rub against the frames, I need to try and adjust them but I've heard the plastic clips can go over time. Are those something I can replace on their own, or are the integral to the regulator?
I'm pretty unsure about which spring / strut combo to get. The springs especially seem hard to figure out - I'd like a very mild drop since I still have 14s on there, but don't want to compromise the ride. Would the ECS KYB + H&R cup kit be a decent fit with the 318?
1991 318iC
-All fluids
-Steering guibo
-Drivetrain guibo
Things pending:
Things next:
-rear axle seal
