Convertible top won't go down correctly
  • spyder918
    • Apr 2019
    • 144
    I just picked up a 91 E30 vert. I tried manually opening the top and it seems to keep getting hung up on the edge of the backseats. I can't seem to figure out why. I've watched several YT videos and still can't figure it out. Is there a step I'm missing?
  • Tzantushka
    • Nov 2018
    • 390
    Assume you have a power top you're trying to manually operate?
    Or...
    A full manual top
    (power top that has a broken motor and been converted to a manual)
    E30 320i vert
    But daily drive is Volvo V60 Polestar
    • flyboyx
      • 8371
      or....power top is broken and has not been converted to manual.
      Gigitty Gigitty!!!!
      • spyder918
        • Apr 2019
        • 144
        Or...
        A full manual top
        Yep, it's a power top that I just converted to manual. I made sure the 2 rods were taken out and all motors disconnected.
        • Tzantushka
          • Nov 2018
          • 390
          Ah, I'd say your 2x tension straps that run the longitudinal length of the top are stuffed.
          Hard to explain, but sounds like you have a section of the roof (between the lateral support bows) that keeps bending forward (and getting caught on the rear seat).
          You'll need to push/tuck that roof material back towards the rear of the car.
          This video best explains it...
          E30 320i vert
          • spyder918
            • Apr 2019
            • 144
            That was it!! Thank you!! Damn I would’ve never figured that out!
            So much gratitude and appreciation for you guys and this forum..I’ve learned so much!
            [/B]
            https://www.youtube.com/watch?v=DXWk0a2-D7o
            • funcrew
              • Jun 2007
              • 1223
              It always impresses passengers when they have to whack the fabric into place so you can drop the top. You will love the car.
              "If the sky were to fall tomorrow, the tall would die first."
              -Dr. Paul Forrester
              Do I LOOK like I need a psychological evaluation???
