so wil the 318i non convertible lowering kit work for the 318 convertible?
The Cabrio Suspension Thread
This is a sticky topic.
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
aboout 3/4 to n inch drop.
Not the best before and after pic but here it is. I think would be a great set up for a 325 instead of 318. I thinking of cutting a coil in the front...
Before pic is with the top up
After pic is with the top down
How do you feel about the shocks? Satisfied?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Fronts will work for sure. The rear will likely sit a little lower that original spec. The back end of the vert is quite a bit heavier. The rear of the 325 and 318 vert is the same so rear vert springs are interchangable. Eibach Pro kit front springs are:
BMW spring 325 305mm 318 279mm
12.5 mm/21 Newton 12mm 20 Newton
or 119 lb per ft or 114 lb per ft
Not sure of the specs for the rear but if you contact Eibach tech department they will give you the details.
Eibach pro kit for vert pn
318ic = 2010.240
325ic = 2010.140Comment
Hey can anyone with cab specific H&R springs and bilsteins sport shocks tell me how much camber and toe they have on the rear tires. I have something like -3.5 each side for my DD so I am doing up the whole rear subframe with all new bushing and the IE weld on adjustable toe and camber kits. I want to know if my neg camber is because of wacked bushings or just it is that low.Comment
