The Cabrio Suspension Thread
This is a sticky topic.
  • Kwaaahhh
    • Apr 2008
    • 843
    #31
    Anyone?
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      #32
      ^ Your best bet would be coilovers, like Ground Control or H&R. Then you could spec the ride height and comfort level exactly to where you want it.
      On another note: Is anyone running H&R Sport springs for the coupe/sedan on their vert? I thought it might be a good way to get my car lower, as they are slightly shorter and would still match my Bilsteins. Pics would be great.
      • Kwaaahhh
        • Apr 2008
        • 843
        #33
        Something like this:
        http://www.ground-control-store.com/...p/II=121/CA=68 ?
        • ethirdy
          • Nov 2007
          • 406
          #34
          '87 vert
          H&R Race/Bilstein Sport
          E30 M3 rear swaybar (14.5mm) with IE poly/alum mounts, OEM links
          AKG poly TA bushings, subframe bushings
          AKG poly motor mounts
          OEM trans mounts
          Rides on rails - wouldn't change a thing :)
          Originally posted by alpinaclone
          Since the real economy is in the shitter, I say we start our own.
          This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
          • oekundar
            • Sep 2007
            • 964
            #35
            Thought I would post these pictures here:
            Comparison of the stock vert springs with the stock M3 springs (front only-for now)
            BMWCCA #389756
            • oekundar
              • Sep 2007
              • 964
              #36
              More pictures....and even more questions...finally completed the M3 suspension all around...here is the side shot of the car:
              Driver's Side Front:
              Passenger Side Front:
              Rears:
              So...why is the rear sagging? I'm tempted to put my stock rear Cabby Springs back on just to try and even it out...
              Oh...the setup is as follows:
              All new CABs and bushings
              New outter tierods
              New front sway linkages
              M3 Springs
              Front Stock struts
              Rear Bilistein HDs
              Thanks!
              BMWCCA #389756
              • CorvallisBMW
                • 13039
                #37
                The rear is sagging because the cabrios are so much heavier than an M3. Remember, the cabrio has 250 extra lbs over the rear axle compared to a coupe, while the M3 has a bunch of fiberglass goodies that make the weight difference even bigger. You need stiffer springs or it will sag.
                • Wishno87
                  • 6025
                  #38
                  thats strange because my car is on M3 springs and compared to my dads car which is bone stock my front end is alot lower but the back and is a little higher
                  • Aerton
                    • Oct 2006
                    • 729
                    #39
                    "My cab is running factory cabrio mtech springs (-20mm) and stock shocks."
                    Boomer and Julien suggested I use the M-Tech cabrio specific springs, that sounds like a great idea to me, and I would imagine I can run Bilstein HD's if they are running stock shocks. Now where do I get new M-tech springs, on real oem.com the springs for my 325I list for 3
                    $300 each never mind M-tech. Does H&R make M-tec cabrio spring replacements??? Anyone here running these????
                    WTB-Strut Bar
                    • CorvallisBMW
                      • 13039
                      #40
                      Just buy H&R cabrio springs. Done.
                      • Aerton
                        • Oct 2006
                        • 729
                        #41
                        Hold on, so witch cabrio springs, to go with the HD Sport or do they have something compatible with the M-tech cabrio?
                        WTB-Strut Bar
                        • CorvallisBMW
                          • 13039
                          #42
                          H&R only makes one kind of cabrio spring. It's the H&R sport cabrio spring.
                          It doesn't matter if your car is m-tech or not, since you're replacing the springs. The H&Rs should be paird with Bilstien Sport shocks.
                          • Aerton
                            • Oct 2006
                            • 729
                            #43
                            WTB-Strut Bar
                            • Aerton
                              • Oct 2006
                              • 729
                              #44
                              Well that defeats my intention of getting M-tech cabrio specific springs. I want a slight drop, in NY/NJ you will bust an oil pan faster than you will get mugged. So I'm looking for an alternative to Billy Sports.
                              WTB-Strut Bar
                              • CorvallisBMW
                                • 13039
                                #45
                                Billy sports are shocks and have ZERO effect of ride height. Springs determine your ride height, and I dont think H&R sports are much lower than m-tech springs. Good luck even finding m-tech springs, let alone a set you want to pay for. Here, look at my car. It's riding on H&R cabrio sport springs and Billy sport shocks:
