E30 manual top operation troubles!
  • danewilbanks1
    • May 2020
    • 9
    Hope all is going well!
    I'm running into an issue with a convertible I just purchased. Among other things, the operation of the top isn't working at the moment. When I pull the handle behind the driver's seat, I hear some clicks but am unable to lift up the storage lid. I took the molding off around that handle and unscrewed the handle to see if the cables were connected to it in the back. They appear to be both connected to the handle. While trying to disassemble the handle of COURSE it snapped in half and a new one is on the way.
    Where do I start in remedying this issue?
  • Sm_simpson
    • May 2016
    • 3
    Gotta ask the basic question: Do you know there is a safety catch you need to also activate to open the tonneau cover?
    it is under the cover, on drivers side. Just slide your finger under the cover and you will find it. Basically just above the handle for the main latch.
    Just like the hood on every vehicle.
    • 101
      • Jul 2011
      • 764
      I had a similar issue when I first got my convertible. Ultimately I was able to use a screwdriver at the latches and trip them open. Once I had the tonneau cover open I lubed and tightened the tension on the cables. They had apparently stretched a bit over the years.
      101
      The E30 collection:
      1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
      1987 325is - Delphin / Black Sport (son #3's)
      1987 325i Convertible - Triple Black
      1989 325iX Coupe - Diamondschwarz / Black Comfort
      1990 325iX Coupe - Sterling Silver / Grey Sport
      1981 Fiat 124 Spider 2000 - Green / Tan
      1998 Volvo V70 GLT - White / Tan
      1998 Volvo S70 T5 manual - White / Taupe
      2001 Ford Windstar - Silver / Grey (parts hauler)
      2006 Lexus GX470 - White / Tan (tow rig)
      • Mars_e30
        • Feb 2007
        • 304
        Worst case, you can remove the back seat and access the bolts that fasten the locks and safety latches.
        • danewilbanks1
          • May 2020
          • 9
          I'm ready to look stupid. I complicated a very simple thing haha you were right it was that catch that was there. Thanks a ton.
          • danewilbanks1
            • May 2020
            • 9
            i'm actually just a mongoloid - I was unaware there was a secondary latch to release.
