Howdy. I recently bought a new fuel pump, fuel pump relay, and battery because my 88 325i convertible was not starting even with continuous cranking.. both relays have tested good. It will crank but will not light off. After installing the parts when I turn on the key the relay clicks multiple times but does not turn the fuel pump on. But when I hotwire the relay it does turn the fuel pump on but will not start even then when the fuel pump is running. I'm hearing fuel traveling to the engine and feel it thru the lines too. Is there something you have to do to reset the injection/ignition system once you replace all these things? I've also tried cleaning off the CPS as it was caked in oil with no result. Any help would be appreciated. Thanks
Sent from my SM-G975U using Tapatalk
