M10 1.8L Base MS tune anyone???
  • Whit3 E30
    • Dec 2013
    • 138
    Hello, I have a 1984 318i with the M10 that I did some upgrades to.
    *Ported an Polished heads
    *Port matched intake
    *Bigger valves with a 3 angle cut
    *Mild cam
    *Upgraded valve springs N rockers
    *4-1 Long tube headers to a 2.5" collector
    ​​​​*2" straight pipe exhaust with a 2.5" Borla muffler
    *Stock bottom end
    *Stock distributor with V.R sensor for crank position/ignition timing
    *Aftermarket GM 3 wire Throttle Position Sensor
    *Aftermarket GM 2 wire I.A.T Sensor
    *Stock E.C.T Sensor
    *Megasquirt 2 v3.57 board running my injection and ignition
    *Innovate motorsports Lc-2 wide band O2 sensor controller w/ Analog gauge
    I was wondering if anyone had a semi similar or just a stock M10 base tune for me to start with so I don't blow anything up when I try to turn that key for the first time. I appreciate any and all POSITIVE informational feedback and /or tunes for me Thanks!!
  • Jaxx_
    • Dec 2009
    • 1880
    this was my NA tune for a stock m10b18. You'll have to adjust some things like the trigger settings, required fuel, and o2 settings, but should get you started.
    • Whit3 E30
      • Dec 2013
      • 138
      Originally posted by Jaxx_
      http://jaxxd.com/e30/natune.msq
      Amazing, thank you, what did the tune produce with your setup?
      • Jaxx_
        • Dec 2009
        • 1880
        93whp/90ftlbs, on an un-opened 200k mile engine, with questionable compression on cyl 4. I don't think I have the dyno graph anymore, unfortunately. It pulled about as expected for a sohc 1.8L and much better in the mid-range compared to L-Jet. As most m10 318 owners know, you can feel the timing come in between 3k and 4k on L-Jet. The car ran 16.88 @ 80.5mph in the 1/4 and I believe 2240 lbs at the time.
        The car had an aftermarket cat and ansa muffler, along with a simple cone filter. Also I forgot to mention that the engine didn't have AC or power steering and the water pump and alternator were under driven a little, with a 4.5" crank pulley.
