MAF IAT resistance values for megasquirt, and question bout fuel maps
  • Gruelius
    • Oct 2009
    • 298
    Hi all
    First question,
    What are the resistance values for the IAT sensor in the maf? i would like to use this for my megasquirt setup, will get a proper GM IAT later on when i change the inlet piping but untill then id rather just use it so yeah
    Also anyone got a good place for NA maps? ive had a look at some ive found online and the NA section of turbo maps but they run a bit too lean for my liking, this is my one but assume its map not fuel load on the left lol
    ill chuck on a cruise area when i figure out what areas i should have.
    RIP 84 323i coupe 5spd w/ 14psi
    89' 318i
  • NC325iC
    • Mar 2004
    • 6565
    Originally posted by gruelius
    also anyone got a good place for na maps?
    +1
    • tn325i
      • 1154
      I don't really have the info for the afm values but I do run MS and it is hazardous to actually use other peoples maps. You may get away with it but you run into way too many variables. I have looked at so many diff files for MS I should be cross eyed.. But the best way to deal with it is using the correct sensors and tuning to your own setup..
      It really depends on where you are as far as capabilities.. You can look at others maps don't get me wrong.. But consider them guidelines and personally I would not risk trying to actually run one.. You could really screw stuff up..
      Don't ask me how I learned this...:(
      Just my .02
