tps question
    tps question
    what tps can I use for tuning the megasquirt. the stock bmw one is just an on off tps. I need one that can tell when you are mid throttle also. I tried to use a nissan tps but Its rotates backwards from the bmw tps so when I should be running the acceleration file it tries to run the deceleration file. Anyone have some advice, I either have to build a new throttle body, or find a different tps.
    I think the type of tps I need is a rheostat one
    " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
    m50tps
      M30b35 6pin is a direct bolt-on tps.
      Best one to use.
      M50 you need an adaptor bracket and make sure it seals in the o-ring.
      The plug will be facing IN unless you flip throttle plate stick thing. (don't know the name)
        Originally posted by LowR3V'in View Post
        ...you flip throttle plate stick thing. (don't know the name)
        LOL, the throttle shaft ;)
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          Its good to know other people have had this problem. thanks for the help :)
