Megasquirt guys.. Are my parameters correct?
  • fiftytakedowns
    • 2460
    Hey,
    So I just finished building my car
    bmw 2002
    2L ported and polished head bigger valves 290 deg cam
    8.5 compression.
    and a big ol Turbo
    Ive got a problem where I can't get it to start
    what is weird is that I will crank it, and it will mini fire, but not quite get full. I checked that it is getting spark.
    symptoms:
    It will Turn over much much Faster and continuously if I create a vacuum over the intake throttle body (with my hand), and it wont all of a sudden stop cranking like:
    crank crank crank crank Shump,(sudden stop), Crank crank crank crank.
    Im trying to eliminate my tune as a possibility.
    I am also Running EDIS
    here is MY like Tune:
    (by clicking the link it downloads it to your computer)
    [/url]
    Team USA Wrestling 67KG
  • whodwho
    • Jun 2008
    • 1547
    Sounds like too much initial advanced timing by table or by reference.
    What did you use for a CPS and timing wheel and did you find a good reference for the sensor angle? Have you verified it by a timing light? (not the easiest when not running but may help)
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • fiftytakedowns
      • 2460
      ill check that out, thanks man.
      [/url]
