HELP WITH IDLE WAR chip tunes.
  • bmwguy325is
    • May 2011
    • 1263
    Ok so I have been chasing this problem. I just cant get the car inspected until it has a normalish idle. Right now I have and 1300 RPM idle.
    I have replaced. ALL hoses intake boot. I have hose clamps on things that did not normally have them
    I have a new IVC
    New and working correctly TPS
    If I run the tune Miller recommends me the car runs awsome but high idle. If I run a stock tune the car idles fine just wont run right. Runs lean.
    So what can I adjust to help this issue? Total nood to tuning.
    I have set the idle RPM super low but it is unresponsive.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
  • Bearmw
    • 1323
    What does Miller say you should do?
    • bmwguy325is
      • May 2011
      • 1263
      Fix all the stuff I have fixed.:curse:
      • Martinator
        • Dec 2010
        • 8
        Can you change the idle map to match the stock tune's idle map ?
        My war stuff uses an x5 v8 maf & the miller idle was very fat. Eventually, the idle got much better leaning it out with the wideband o2 sensor. I ended up using a measured idle hose after going through 3 new idle control valves that the war chip couldn't control. Brody's 535 doesn't have an idle control valve either. Surprised idle works on any war stuff.
        • bmwguy325is
          • May 2011
          • 1263
          I dont have any way to know how to tell if the car is lean or rich just listening. I am guessing since it idles up it is lean. The stock map has low values for idle and the tune the gave me ups the values. I am tryingto up the values see if I can fix it.
          I am running the 3 inch MAF on a stock internals M20 with full exhaust.
          So how did you go about making that hose? Just guess work?
          • bmwguy325is
            • May 2011
            • 1263
            SO...
            Ya long story short. I had an unresponsive TCV.
            I just pulled it off and plugged the holes. BAM! proper idle.
            Only side effect I can for see is the car running like it has no choke when cold.
            • Bearmw
              • 1323
              So your new idle control valve was nonresponsive...interesting. Was there voltage to it?
              • bmwguy325is
                • May 2011
                • 1263
                I wouldnt say it was unresponsive. I could get the car to idle 3k if I wanted. It just never went lower than 1300rpm. I have been driving the car for a few days with no ICV. Its a lil rough when cold but then I can heal toe pretty well. The voltages all matched what the manual said they should be
                • Bearmw
                  • 1323
                  What is the idle speed now once warmed up?
                  • bmwguy325is
                    • May 2011
                    • 1263
                    A nice steady 900
                    • brody
                      • Jul 2009
                      • 334
                      Martin, my 535 had an ICV, every car we've ever built retains the ICV and works great. We will be making a video soon for those M20 guys with high idles. We've finally had a couple local cars have this issue and we've been able to confirm its a mechanical adjustment problem in regards to how open or closed the throttle plate is.
                      The WAR chip doesn't do anything different to idle control, it just gives you the power to set the speeds, timing and fuel. If you ICV system is properly set up and functioning the ECU will control it like always. Another thing to think about is when the AFM is present, at idle it is acting like a throttle body in the sense it's pretty closed. So if your throttle plate is too far open in adjustment, you won't notice with the AFM. Remove that restriction and look at that. The previous owner must have had a failing ICV, cracked the throttle plate open some and now with the AFM restriction gone, you get a high idle that can't keep up to what is going on.
                      Again, we will have a video showing how to determine this on your car shortly.
                      • bmwguy325is
                        • May 2011
                        • 1263
                        So Brody what you said makes sense. My car idled fine with a stock sized MAF which is what I started with. I then upgraded to a 3 inch one. Then I had the high idle.
                        I did try to close my throttle plate by cranking the set screw lower. It still idled high. I removed the ICV from the info on here and a local tunner. He does it to hondas too.
                        Ill wait for the video though. Mean time I am running the car sans ICV and it runs great.
                        And yes I checked EVERYTHING on my car and replaced everything too.
                        • CorvallisBMW
                          Long Schlong Longhammer
                          • 13039
                          I recently replaced my old TPS on my m30 after finding I wasn't getting a closed circuit on WOT. Since putting in a new one my idle has jumped to 1300rpm as well. I might try the ICV trick tomorrow to see if it makes a difference.
                          • bmwguy325is
                            • May 2011
                            • 1263
                            To do it you have to block off the holes. For my trial run I duct tapes the holes. Then found propper plugs
                            • CorvallisBMW
                              • 13039
                              Changed out my ICV, idle seems to be behaving now
