Fan relay control
  • LowR3V'in
    • 4209
    Fan relay control
    Does it matter if I use either hi/low fan speed relay if it's an aftermarket single speed fan?
    Right now it's hooked to the lowspeed relay so I can turn it on with the a/c switch
    but not sure if I should use the hi speed relay instead.
    thanks.
  • Jaxx_
    • Dec 2009
    • 1880
    no. they have the same power outputs and everything. I think even the same gauge wire, but I'm not 100% sure.
    give me your year/model and I'll look at the wiring diagrams if you want.
