m42 turbo tune??
  • jackhammer12
    • Jun 2011
    • 133
    m42 turbo tune??
    I just finished my t3/t4 kit, and was wondering what kid of ecu was recomended or usually used? Here is current list....Would just a megasquirt work?
    -Turbonetics turbo t3/t4
    -Good n tight Turbo manifold
    -New in box VAC 42 lb/hr high impedance injectors
    -Aem uego air fuel meter with wideband sensor
    -Turbonetics open wastegate(have both 12psi and 9psi springs)
    -Blitz blow off valve
    -Sparco front mount intercooler
    -Custom mandrel bent 3 inch piping from turbo to downpipe all the way back to high flow cat and 3inch Magna flow turbo muffler
    -Tapped oil pan
    -All intercooler piping/clamps and oil lines needed
    -14" electric fan
    -3.73 LSD
  • MaksV
    • 1042
    As always you have a few tuning options:
    1. Megasquirt
    2. WAR chip/blowthrough
    3. Ostrich 2.0 / TunerPro
    4. TRM
    5. Custom tune from a local tuner.
    each option has its pros and cons.
    CHEAP REBUILT INJECTORS
    Need Quality Brakes? BimmerBrakes has it!
    For anything Else go with BluntTech!
    • MF DOOM
      • Apr 2012
      • 944
      Blueapplesoda sells a megasquirt thats plug n play. Would be worth checking into. MS seems to be the favorite among everyone. I couldnt tell you anything about it besides you can find an endless amount of info on it.
