Well i have pretty much everything soldered etc. besides a few steps where i was a little confused.
these step #'s are from http://megasquirt.info and then go to v3 main board assembly guide
Step 50,51,52 i am planning on getting MSD 6a ignition and a blaster 2 coil, should i just follow the msd 6a installation link they provide?
do our cars use a PWM idle valve?
Step 65 - once again should i follow the msd 6s instructions?
Steps 69-72 - i installed step 70 & 71, i am planning on using 42lb injectors, so should i worry about installing step 69
thanks alot guys.
thanks alot guys.
